2017 turn signal fuse keeps blowing
The turn signals and hazards lights (exterior and dashboard) stopped working in my 2017 Toyota Camry Hybrid XLE so I replaced the fuse. This fixed left signal lights, but the exterior right still still would not turn on (although the dash right turn signal would flash three times and then stop). A month later the left signal stopped working again.
I've read that if the fuse keeps blowing, then it may be the relay/flasher; however, I have been unable to find a turn signal relay for this make/model when searching on the internet and also don't know if it exists. When I called Toyota they say a blinker or turn signal flasher/relay part was not pulling up for this make/model. I appreciate any insight into what the issue could be, recommended actions, and/or information on a relay for this make/model that are associated with these lights. Thanks! |
Do the hazard lights work and if so does a fuse blow when using them?
Hi Joey thanks for the response. When the hazard lights are activated, the left exterior lights illuminate but the right ones do not just like when using the turn signal. I'm not sure whether keeping the hazards will blow the fuse, but i'd guess that it might.
Another potential clue i previously failed to mention is that when I put the signal arm in the right turn position, the right turn signal on the dashboard flashes three times and then stops. If I put the signal arm in the right turn position a few times in a short amount of time i.e. repeatedly, the dashboard right turn light will stop flashing altogether. As I mentioned earlier, the front and back right exterior blinkers do not turn on at all.
