2018 Camry SE power outlet fuse
I cant find a fuse diagram that shows the location of the fuse that powers the power outlet. I checked the fuses one by one and they all look fine. It stopped working when i was running a small air compressor to air up the tires. Does anyone know if it is a fuse or relay problem and its location?
Thank you> I found the fuse box located under the driver side dash above the left kick plate.. It was a 15A fuse that was blown.
