89 camry gauge cluster bulbs
ok my 89 camry cluster bulbs are just dim i have turned them up all the way
and still its really hard to see them when dark ? driving on the highway sucks i jus cant see the speed... Is there a bulb i can put in that will brightening it up so i can see it? And if so what are the ##s on the part.. thanks |
The cluster bulbs are wired up with all other instrument lights such as climate controls. Are all lights dim or just the speedo? If all lights check dimmer switch voltages. This should vary with knob position from 0v (fully CW) to 12v (fully CCW) between green and white/black wires.
Make sure the cluster bulbs are not yellow tint. The cluster has a number of bulbs, perhaps a few are burned out. The bulb P/N listed is 194 available in many brands. |
Hi, Camry clusters use Wagner / Toshiba V-2 sockets bulbs.. Sizes T5 , T6.5 , T10
we carry all Original toyota bulbs for replacement please check out - www.speedometerbulbs.com/collections/toshiba if you anybody needs replacements for theyr clusters / speedometers thank you -Bryan |
