89 wagon power window issue
My windows and locks were not working at all this morning so I replaced the 30a cb's by the driver side kick plate and the relays which fixed the door locks but I still cannot work the windows at all. Any suggestions or wiring diags?
Thanks |
Fuses are good as well
Power windows receive power from Power main Relay. This relay is powered by Gauge fuse and the 30A breaker.
Do any of the individual window control work? Sometimes the wiring running between the drivers door and chassis breaks down with door usage (wire harness flexing). Check wiring between door and chassis. |
No, none of the doors work at all. The door locks work for the driver and passenger doors though. I will check the wiring between the driver door and chassis. I will check the wiring and see if there is any breakage and reply. Thanks again!
