'90 5S-FE swap into '98 Camry
Old 05-02-2009, 11:02 PM
camry4eva's Avatar
Default '90 5S-FE swap into '98 Camry
Hey my name is Tim. Ok...to make a long story short...I spun a rod in my camry but refuse to junk it. I was gonna put a 3S-GTE in it but that was too expensive of a project. So here's where I am now. I have the camry with the spun rod and I just purchased a '90 celica gt with the 5S-FE of that year. that car isn't running because it has a fried wiring harness, but i don't think that i need it to. I should be able to swap the long block into my car. my first question is whether that will work out. obviously the '90 5S-FE will bolt into my motor mounts, but will everything wire correctly. if not, will i need a new ecu, wiring harness, or both. i understand that i''m also gonna have to splice some wires. also, i figure i'm just gonna put the 3S-GTE into the celica shell afterwards and try to get my hands on the E153 V6 camry tranny. So yea...pray for that. What do you think about everything?
Old 05-21-2009, 11:17 AM
The may be to great of difference in years.
Toyota upgraded the ign system, checked the block design, etc. You might be able strip the 1990 engine to a short block and add back the head, etc from the 98.
These engines are very cheap on the used market, suggest finding on closer to the one your are replacing.
Old 06-04-2009, 06:40 AM
MagicOPromotion's Avatar
Default 90 5S FE swap into 98 Camry
so the search engine is fubar here at work and im askin n e ways. i purchased a type r 98 spec motorobd2 swap from hmo.. what and i going to need to do to wire it up into a 93 del solobd1? am i going to have to change injectors and all that?
carlos1787
05-23-2009 05:57 AM
ndnashlen
04-06-2009 04:11 PM
kensand
03-24-2009 08:43 PM
marv8
10-05-2007 09:02 AM
azazel_18_2
04-22-2007 05:42 AM
Quick Reply: '90 5S-FE swap into '98 Camry
