92 SE Misfire?????? Help
Hi Guys, I recently purchase a 92 camry se 5spd 3.0L , 113,XXXmiles
I have already done an oil change, fuel filter, pcv replacement. the spark plugs were changed prior to purchasing , but i did take all 6 out to check the gaping. Once the car is at normal temperature the revs would go down to about 700 and it sound like it miss fires between 700-1000 rpm. 1- the misfire is not constant 2- only happens after car is warmed up 3- after a few mins of missfiring the car would shut off. ------------------------------------------------------- Immediately i thought Rotor, Spark Wires or distributor. so i took of all the wires , dist. cap and rotor. I did see some small brown deposits on each of the small terminals on the inside of the cap. So i cleaned them up like new Also the wires seemed to be fine , I only did a visual inspection. Rotor was also fine, nothing out of the ordinary. after i put all the wire back in their respective positions, i started the car let it warm up , and the revs dropped to about 750 (normal) ,NOW it does not shut off on it own. BUT I still have an irregular misfire after the car has reached normal temp. Any ideas? Thanks Alot in advance. |
+1
I did also put in injector cleaner but i haven't driven the car around, only standing , no plates yet
