95 camry starting problems
so im still having problems starting my camry. it first started when the car died because of the am2 fuse kept popping. i found a bare wire in the dizzy, so i replaced the dizzy. still no start. then i swapped out the ignition module, still no start. the big white and red striped wire going into the ignition module in the middle has power and has power plugged into the dizzy in the 2 port plug. i have another camry the same year so i checked the ignition module plug and the white and red wire has power and the black and red striped wire has wire has power. plus the working camry has power at the dizzy on the 2 port plug on the brown and red i think it is, but not the white and red. any ideas on this??? thanks mike
