96 camry no start
Hope this is in the right area. I have a 96 camry that just cranks. Tested spark plugs n got no spark. Distributor, cap, rotar are replaced. Coil pack replaced. Ignition module replaced. Still just cranks. Tried starting it with starter fluid and it just cranked. What shold I check next?
What engine, V6 or 4-cylinder?
The engine have a remote cam or crank sensor? Check for +12v at the coil pack and ign module (black/red wires). Check for broken timing belt. Crank engine and view rotor for rotation. |
4 cylinder rotor does turn timing belt is good. The coil and ign module are new but the ign module is not getting power if I remember correctly. Engine light is on hooked it up and throwing a code for the ign module. Couldn't clear the code. Would u say the ecm is bad.
Ign module not getting 12V power or ECM power?
What is the code number? Does the engine have remote cam or crank sensor. Are the sensors built into the distributor or is one or another located off the timing belt pulley (timing cover area)? |
