96 camry weird issue: obd port, stalls when gassed, need guru
First off. The car is a 96, 1mzfe
Car wont rev past 2000, will stall and die. Replaced: New fuel pump New fuel filter New spark plugs Used tps Used fpr Used cps Checked for vacuum leaks Has a steady idle but when press on gas will slowly rev and die. Un did exhaust before cat thinking it was clogged same thing. Check engine light is on. Bought 2 scanners, both would turn on but no signal from ecu. Bit the bullet and bought a scanner for obd1 and 2 Turns on, still no link. Whats going on? Bad ecu? |
Could be bad ECU.
Check OBD fuse 7.5A. On ODBII plug following: Check #16 terminal for 12v power at all times. This is a black wire. #4 wire is grounded, white/black. #5 is wire shielding wire, brown. #7 is signal wire from ECU, white. With OBD plug oriented facing you, and the wider part of the trapezoid connector on the bottom, the orientation is. 16 to 8 Top 7 to 1 Bottom The plug only uses 4 terminals. |
