battery warning light
Old Feb 22, 2026 | 11:50 PM
davcamryzz's Avatar
Default battery warning light
I have a 2004 Camery 4cy and the battery warning light started popping on at around 2000 rpm and goes off at 1000 to 1500 rpm. Checked battery and seems fine . Checked alt and it is charging at 14 volts running. I put a reader on it and it shows no faults. Does anybody have any ideas as to why it pops on at higher rpm. Belts seem tight, No squealing or noise. battery is charging at 14 V while light is on. Any help would be appreciated.
Old Feb 26, 2026 | 10:07 PM
I'd test the battery and alternator. Most parts places will test both for free. Start with the easy stuff.
Old Feb 27, 2026 | 11:53 PM
Could be a bad alternator or the regulator inside the alternator.
Pickup a voltmeter that plugs into the power outlet or cig lighter (Amazon) and watch the voltage. Try loading down the alternator output with the heater, lights, etc.
hobbitsan
Aug 30, 2022 03:27 PM
kt77
May 30, 2017 12:42 AM
WGray
Jun 3, 2015 10:24 AM
gfunktastic
Sep 12, 2014 06:09 PM
ice1968
Feb 6, 2011 10:00 PM
