Brake lights not coming on when pedal pressed.
My tail lights will come on when I turn the headlights on, but when I press the pedal, nothing happens. When I turn the headlights off, the tail lights go off and still, nothing happens. |
2 Attachment(s)
what year camry ?
up under the dash there is a stop light activation switch on the brake pedal adjustable and replaceable |
Originally Posted by dirty hands
(Post 95092)
what year camry ?
1995 camry stop light activation switch
should be like the metal thread and nut image |
I replaced the switch and nothing happened :/
1 Attachment(s)
that switch has 12 volts to the bulbs
did you do the adjustment at the pedal so the switch fully releases when pedal depressed brake light bulb has two elements inside fit a new one to be sure |
Returned the switch at Autozone and they gave me another one and it worked.. guess I got the lemon? Thank you for the help!!
good to know the pedal switch resolved the problem
thank you for the feed back |
