bymy
Check engine and vsc lights are on Napa coded at p0079 is that an O2 sensor and if so where is it located?
bymy
I forgot to mention it is a 2007 camry xle with 94k miles
V6 or I4? There are two O2 sensors on these cars. Did they tell you anymore than that? Usually is will say bank 1 or bank 2.
Originally Posted by Patonium
(Post 85148)
It is a v6. another code that showed up p0057 also lower bank 2 this one is from advanced auto parts. |
Check out this link:
OBD2-OBDII Engine Light Trouble Codes Definitions, Description and Repair Information | Engine-Codes.com search the code in the upper right and it will break it down into possibilities. I'm a little limited when it comes to the V6 so there is my two cents. |
