camry ignition module
so i have a 95 auto camry that was popping the am2 fuse, i took the dizzy apart and found that some wires were falling apart and popping the fuse. i replace the dizzy and still wont start. my next idea was the ignition module i have power going to the 3rd spot on the big plug. i also have a 94 camry auto and i check that plug to so what got power on it, and it was the 1st and 3rd, and that camry works. so on my broke camry i only have power on the 3rd. what is the 1st one going to? or where to find a wiring diagram? i checked the fuses and the am2 doesn't pop any more, but the ign fuse inside the car was poped, i replaced and doesn't pop anymore, any ideas please help???? thanks mike
The AutoZone website has a few wiring diagrams.
V6 or 4 cylinder? Ign module as in ignitor or the cars computer. And what color are the wires? |
it is a 4 cy. i believe the wire that doesn't have power is a black with red strip. on the other working camry it has power, im just trying to figure out why and where that power is coming from. and thinking maybe if that had power that could be the reason why it's not starting. i was looking last night for a diagram of pin outs but i couldn't' find anything in manual or online. know of anywhere to start testing? or to start looking?
If your talking about the ignitor the Black/Red strip wire is the coil ground. Goes from negative terminal of the ign coil to the C- terminal of the ignitor.
See private message. |
