Cigarette lighter socket in the trunk
Old Jul 10, 2025 | 10:14 AM
slavo_s2k's Avatar
Default Cigarette lighter socket in the trunk
I want to install a 12V cigarette lighter socket in the trunk (for connecting a travel fridge). What’s the shortest/easiest way to run power to it? Can I find a power source somewhere in the cabin, or do I have to run it directly from the battery? Camry MR '22
Old Jul 10, 2025 | 04:05 PM
There should be a fuse box behind the driver's side dashboard. Can use a fuse tap on a circuit that has enough constant power.
The trunk light circuit should have constant power, but the amps may not be enough.
Might run a fused wire direct from the battery along the driver's side frame rail as this should already have wiring present that goes to the trunk.
Old Jul 11, 2025 | 09:25 AM
slavo_s2k's Avatar
There are fuses on the driver's side — do you happen to have a fuse diagram? That would help me know which one I can tap into. Just to add, my car is a hybrid version.
Old Jul 11, 2025 | 03:35 PM
Don't have schematic.
Is there something in the owner's manual?
For $25 one can access Toyota service info for 2 days at the website below.
TIS
slider46
Jan 14, 2018 07:40 PM
hlavender
Jul 7, 2010 06:16 PM
jaycamry26
May 31, 2009 07:54 PM
pakixd
Oct 18, 2008 10:55 AM
Collin16
Jul 26, 2007 10:29 AM
