clock
clock
For some reason the clock no longer shows on my 2001 Camry.I checked the fuse box under the hood but did not find any designated fuse for clock only.I also checked under dash to see if there was another fuse box but did not see one. Any ideas other than taking the dashboard apart which I am sure will cause rattles in the future not to mention the expense.
RE: clock
you should be able to take out the instrument cluster bezel (the black guard around the cluster) and the clock from there can be easily taken out and replaced. You can look around on ebay, or call around junk yards and see. It would be expensive for the dealership to replace trust me been there done that.
RE: clock
I've had the same problem a couple of times after plugging in something that sucks too much current.
An answer is here:
http://townhall-talk.edmunds.com/direct/view/.f0e7ad4
An answer is here:
