" D " lite on dash
99 Camry just noticed the "D" lite on the cluster is not lit up when in drive, as i was banging things in came on and then went off a few min later. are these individual bulbs behind cluster or is there a contact switch on the shift counsel?
The contact switch would be on the transmission mounted behind the shift lever.
The bulbs are individual type, twist to lock in. Might be a poor connection where the bulb mounts. The gauge cluster needs to be removed to access the back. |
ill try both thanks
