electrical seatheaters dont work
Old 12-15-2017, 03:55 PM
Rob Wapperom's Avatar
Default electrical seatheaters dont work
hello, I have a issu with both electrical seatheaters off my Camry 2.2 2001.
When I push the swich on there will nothing happened, the fuse is oke.
what can it be?
Thank you in advance;
Kind regards.
Rob Wapperom
Old 12-15-2017, 06:11 PM
Does the seat heater system on/off button have an on/off indicator light? If so, does the light illuminate when the heater is turned on?
Do the windshield wipers and heater blower work?
Old 12-16-2017, 04:51 AM
Hello; the indicator lights are working when I put the switch on, all the other components are working propely.
Regards;
Rob Wapperom
Old 12-16-2017, 12:03 PM
If you have the skills. Use a volt meter to check for 12v power (switch on) at the harness plug for the seat heater. This plug should be under the seat.
It happens the seat heater fails (and both). You can check for an open heater circuit using an ohmmeter. If zero ohms the circuit is open. Compare one seat ohm reading with the other.
lemmon_water
07-01-2015 05:18 AM
zsad123
10-24-2009 07:21 AM
wnmetal
06-29-2009 11:38 PM
wildmonk
03-19-2007 01:30 PM
Quick Reply: electrical seatheaters dont work
