Electrical short
Hello everyone. A few weeks ago I “blew” my factory radio out on my 2014 Camry. We looked at all the fuses and swapped some bad ones out and bam it worked again. But now the check engine light is on. I’m getting the p0560 system voltage code. We checked the battery and alternator and they are fine. So we’re assuming it’s a short somewhere. I’m praying there is an
https://cimg6.ibsrv.net/gimg/www.cam...32de236b73.png easy fix.. please help me. Thanks in advance. |
Have you tried clearing the code and determine if it reappears?
The computer is constantly powered directly by the battery. If the voltage source is broken the code is tripped. Did you remove any fuses such as EFI or P/I (if equipped)? Bad connection between battery and computer? Is the battery good? Check battery cable connections (poor connection). |
