engine problems 2005 camry
Old 10-31-2017, 03:08 PM
baja19622000's Avatar
Default engine problems 2005 camry
I have a 2005 Camry 2.4 it turns over but will not run put it on a OBD2 said at first P0353 I cleared that then it said P0352 cleared that then it said P0351 and that one wont clear changed all 4 spark plugs 2 coils in the middle spark plug second from the right had oil on it changed it now i dont see anymore oil can you help still getting P0351
Old 11-01-2017, 12:46 PM
Do the spark plugs spark when turning the engine over?
Old 11-01-2017, 01:02 PM
yes the engine will run for about a second then shut off
Old 11-01-2017, 01:18 PM
yes the engine runs for about a second then turns off
Old 11-01-2017, 02:56 PM
Check crank and cam sensors.
Old 11-01-2017, 02:59 PM
ok thank you
baja19622000
10-31-2017 01:41 PM
alynne84
09-21-2011 01:39 PM
raptorclaw
05-01-2009 09:02 PM
DaleD
11-11-2008 10:42 AM
gajo385
07-03-2008 08:49 PM
Quick Reply: engine problems 2005 camry
