Fog Light Intallation.
Hi there guys /Gals I just purchased a set of OEM fog light for my 02 Camry , this kit did not come with intall instructions , can anyone tell where I can get the installtion instruction from other that the Toyota Dealers. Thanks
jjs488[8D]
jjs488[8D]
RE: Fog Light Intallation.
the OEM lights usually comes w/an AUX. switch .. and it's a direct current from the battery and ground it out somewhere near the lights.. the closer the better. And just run the wires... make sure no wire is dangling either!
jjs488,
Don't know if you've worked out you're install yet but if not I have some instructions for a 2000 that I can fax or e-mail (PDF) to you. They're 17 pages long so be warned.
I have been using them them for the install in my 98 LE. The connector slot numbers and their wires are a little different but I've almost got it figured out. It may work out perfect for you. It has the instruction for with and without DRL's.
Let me know if you need them.
Herby
Herby
In my install mentioned above I've got everything wired correctly (I think) but it keeps popping the fuse. I'm using the factory harness although it's designed for a 2000 and mine is a 98. I've got the activation wire getting 12V from the large Red/Black wire from slot 7. Should there be 12V going to the switch?
Anybody ever used the factory harness on their 98 or can check theirs out to tell if I've got wired right.
TIA,
Herby
TIA,
Herby
