help! 1996 wagon v6 technical question
Hello i have a 1996 camery wogon v6. i had a nightmere trying to find and figure out the exact name and purporse of the vacume valve on the pressure side of the power steerini saw you wondering if you still have this . i replaced the line because it was leaking and had to torch the switch to remove from old and install to new one, in the process i guess it being original switch it got damaged. i now have a leak and new line is over 500 and im searchin high and low trying to figure this out. any help would be greatly appreciated! james
Im looking just for the switch that has two ports on one side and screwsto the high pressure sid el
ine |
Might be an Air Control Valve.
Is this the switch in the link below: http://www.prostreetonline.com/m/toy...cuum-valve.asp |
