My left blinker is on while low beams are on
Left blinker will work as intended but it’s on while any light mode is on but DRL
Year of car?
2002 Camry LE
(Post 101538)
Year of car?
Does hazard flasher usage have the same issue with DRL?
Well no
(Post 101550)
If hazards work OK with DRL would be looking at the light/blinker switch on the steering console.
I’ll have to get back to you, with pictures.
(Post 101555)
My DRL doesn’t even work.
Originally Posted by Ibraheem Younis
(Post 101551)
It doesn’t have the issue with DRL.
https://cimg0.ibsrv.net/gimg/www.cam...c7950fe89.jpeg |
(Post 101555)
The headlight switch arm rotation switch controls the headlight relay which controls the light situation.
The blinkers and hazards are only linked to the headlight system by the headlight control arm. And here its with the up/down movement of the arm not rotational setting of the switch. Did anyone install an aftermarket alarm or remote engine start system the linked into the cars headlight and turn signal wiring? |
