No Power in Check Engine Light Socket
Hi,
Yesterday I bought 2003 Toyota Camry XLE from a private seller. Today its check engine light came on, I went to Autozone and he tried 3-4 different machines in Check engine light socket but none of them got any prower. Atlast he told that there is no power in CEL socket or may be some fuse is gone or Socket itself is bad. Can u please suggest what should i do next? Thanks a lot in advance Regards Rajit |
Was the ign key turned on?
Yes, Ign key was On.
I also have personal OBD 2 scanned, which works in Collola but not working on this 2003 Camry |
The power wire in the plug is fused- Labeled ODB fuse. A Black wire.
Location is in a fuse box behind the drivers side ash tray/coin box. Box is in the lower left corner of the dash about where your left knee would be. White/Black and Brown wires are grounded. Purple/Black, White and Red wires go to the computer. |
(Post 68088)
Location is in a fuse box behind the drivers side ash tray/coin box. Box is in the lower left corner of the dash about where your left knee would be. White/Black and Brown wires are grounded. Purple/Black, White and Red wires go to the computer. Thanks, I will try to find them tomorrow morning |
It was wrong Fuse.
Replaced the fuse and CEL code P0442 came. I think I should replace Fuel Cap Thanks a lot for helpful suggestion |
