No Spark
No Spark
Hi everyone I own a 92 camry the other day I went out and started it and was moving and it died. It now has no spark. I changed out the coil, distrubitor,igniter. I thought maybe a timing belt but I should still have spark. It has 5S-FE engine. Timing belt has approx. 30000 on it since it was changed. I'm lost as to where to look next. Help
Remove the distributor cap. Have someone turn the engine over while you watch the rotor. If it doesn't rotate the belt has broken.
The belt rotates the cams that rotate the distributor.
Check all the fuses.
Send a private message with email address, can send a file on the ign system.
Thanks for replying Joey Rotor rotates Timing marks seem to be on the mark 10 btc rotor is in line with #1 wire in dist. cap. I have triple checked fuses and fuseable links in dash, left fender and behind the passenger side kick panel.
No Spark
Thanks for everyones help. I located the problem. I had two coils and found out they were both bad. One new and one old. Bought another new one and installed it and fired right up. Never believe all new parts are good. I checked both the primary and secondary circuits with an ohm meter to find the problem.
