99 Camry brake warning light
Old 11-15-2017, 01:48 PM
2wonder's Avatar
Default 99 Camry brake warning light
My Camry dash brake warning light has started coming on while car is being driven. It usually goes off after braking but often will come back on. It seems to do this more often in cooler temperatures. This morning the temperature was in the 40s and light stayed on most of the time. This afternoon temperature was in 50s and the light did not come on during the drive home. I've checked and added brake fluid which had no effect. I do not have means to check for error codes. Any ideas of what the problem may be would be appreciated.
Thanks in advance
Old 11-15-2017, 06:03 PM
Check the tail light and brake bulbs. Clean the bulb and socket electrical contacts.
If you think the issue is the brake fluid level, disconnect the plug.
Lilred
04-18-2016 10:33 AM
Nicholas Bowen
11-11-2015 12:56 PM
LeeM
10-02-2011 10:54 PM
10five
07-24-2009 12:34 AM
Camrydriver
10-01-2008 08:47 PM
Quick Reply: 99 Camry brake warning light
