Please help! AC/Defroster issues
Hey everyone! I would really appreciate any help with an issue im having with my 09 Camry SE 4cyl. I turn the car on and the rear defroster light blinks like 10 times. My ac also only blows from the front vents, not from any of the others and max ac doesnt seem to work. The heat also doesn't work. I thought it might be the ac controls but, I replaced them and I still have the issue. I have seen something mentioning a possible problem with a blend door or solenoid. Anyone have any experience with thIs? Also checked all fuses. This happened at the same time my ac compressor went out. Replaced compressor, expansion valve, drier and cleaned out the system.
The climate control may have its own self check system.
Turn ign switch on while pressing the A/C auto switch and R/F switches (if the system has these) until lights behind various buttons start to blink. The system will then preform a self check and if problems a code number(s) will start to appear in the display panel. |
R/f switch?
Rear/Front
I'm having a similar problem with my 07 camry.... it won't blow heat to the windshield only front vents and my defrost light blinks... please help thanks
Originally Posted by chrisdr809
(Post 92006)
If the lights blinks may be the A/C amplifier and or the vent servo motor.
Read link below and info from poster ekesz13. https://www.toyotanation.com/forum/1...5-seconds.html |
