Power Lock Problem
Hi i'm new here. I just bought a 1997 Camry with 187000 miles for 2450. The problem I have is that I press the unlock button on the remote and the doors unlock. The only problem is my driver's side door shows that it is unlocked, however I can't open the door? Is there a simple solution to this or should I take it to a garage?
RE: Power Lock Problem
Can you open the door from inside?
The system uses steel rods to transmit the forces. Plastic clips keep the rods from falling off the lever arms, etc. A plastic clip may have broke resulting in a rod falling off. You will need to take off the door panel and look around for the problem. Door panel removal is pretty easy. |
Yea, I can open the door from the inside. That is probably it, I'll look into that this weekend.
