srs light blinking
The scan shows code B1144. Disconnected drivers side airbag connector under drivers seat sprayed thoughty with electrical contact cleaner, reconnected and repeated several (five ) times . NO HELP. Any suggestions? i
Year of car?
B1144 is the left side door airbag sensor. Sensor is located at the base of the seat belt retraction system and bolted to the chassis. On Toyota's if an airbag code is set it typically needs to be cleared via a code reader rather then self reset. |
