sudden & Extreme electrical issues
Old 01-08-2011, 07:42 PM
NW78's Avatar
Default sudden & Extreme electrical issues
i am having number of electrical issues with my 1991 toyota camry, for instance: my brake lights no longer work, all of my dash lights are off, heater/AC shut off, tail lights are out and i have to use the manuel overide to shift out of park. ive checked all of the fuses and none are burnt out. i had a alternator and batterie check at Schucks and everything was fine. i am a bit lost on what it could be beside a loose wire or some other electrical issue, please help?
Old 01-09-2011, 12:14 PM
If the fuses for these items are good, then power may not be making it to the fuse.
If the alt were bad the alt light typically would be on, a bad battery would cause starting issues.
Exactly what works and what does not?
billmac
08-03-2009 08:40 PM
calibeep
06-04-2008 09:42 AM
tombs14
05-24-2008 03:42 PM
moh.vze.com
03-06-2008 05:11 PM
mrhaveckz
08-18-2007 05:05 AM
Quick Reply: sudden & Extreme electrical issues
