93 Camry sunroof/dome light quit
1993 Camry sunroof switches and dome light in sunroof accessory panel stopped working. My mechanic says it is the sunroof motor but I do not think he is right. I believe it is a fuse or a relay.. Does anyone have an idea where the fuse/relays are for the sunroof? Also (possibly ) related . At the same time the power antenna ceased to work. Not sure if these all relate or I have separate issues. The fuses shown in the owners manual seem ok. there is no diagram for the relays
It seems like a power related issue and not mechanical
Have you checked the Dome fuse? Location is engine compartment, drivers side.
The power antenna fuses are Dome, ECU-IG and CiG/Radio. The other two fuses are located in a panel, lcation drivers side of dash behind dash ash tray.
