Windshield Wiper Problem- DIY???
1993 Camry..
When my windshield wipers are on at full speed for heavy raining and as they are moving back and forth, they hit the bottom of the windshield making a bumping noise that drives me nuts! I loosening the screws holding the blades in place to adjust them several different times and they still hit the bottom of the windshield's stripping making the noise. Is there something I can tighten or adjust in the wiper motor or inside the wiper housing to stop this problem?? |
Don't think there is any stop adjustment. Are the arm drive shaft bushings worn out allowing the wiper arm move about too much?
The motor and actuator arms are located under a removable louver panel. Remove the panel and check for loose actuator arm end fittings, etc. |
