’95 LE Camry with engine problems
Old 10-31-2006, 01:06 AM
alrtytn's Avatar
Default ’95 LE Camry with engine problems
My ’95 4-cylinder Camry has about 186k miles. Recently, I have noticed that my oil level has been about a quart low and trying to figure out the source of the problem. While investigating the car, the spark plugs were changed and I noticed that the middle 2 plugs outer rubber lining was a red/yellow color. The coolants color was brownish. My thoughts are to (1) do a compression test and (2) do a coolant test for oil…does anyone know how to do these tests or how difficult? My initial thoughts for the source of the problem could be a blown head gasket. Any ideas or am I on the right track??
Old 11-01-2006, 04:56 PM
lavalleemike's Avatar
Default RE: ’95 LE Camry with engine problems
Your probably right i would just drain the oil and coolant and see if there is water in the oil or oil in the water. The brown coolant could be due to rust in your cooling system but, considering you missing oil you may have a blown head gasket.
Gregthegen
02-10-2013 04:20 PM
theiceman447
10-20-2012 08:48 AM
jeeperman
10-27-2008 08:19 PM
miggypilares
01-13-2008 01:14 PM
SarahS
12-20-2006 07:53 PM
Quick Reply: ’95 LE Camry with engine problems
