01 camry 5sp
Hey guys, so I'm new to this forum. I just bought a 01 camry 2.2 5sp 155k on it and it's a great car for the year. So a couple things that I notice its the blower on works on medium high, and high I'm sure a blower motor resistor will fix that and I noticed when i downshift the car will kinda shake when I grabs the gear doesnt matter what gear if your slowing down and downshifting it does that. Also when at a dead stop putting it into 1st is kinda hard but after go thru the gears its smooth it happens to 3rd gear to but not all the time.
Not sure if you guys could answer some of these concerns. Thanks again |
Get the right motor resistor,. One for your climate system, which is either manual or auto heat temp setting.
How is the clutch? Bad motor mounts can cause shaking. |
(Post 99848)
Try starting out in 2nd and determine if the clutch chatters.
