01 camry 5sp
Old 02-04-2019, 07:18 PM
Corollaboy96's Avatar
Default 01 camry 5sp
Hey guys, so I'm new to this forum. I just bought a 01 camry 2.2 5sp 155k on it and it's a great car for the year. So a couple things that I notice its the blower on works on medium high, and high I'm sure a blower motor resistor will fix that and I noticed when i downshift the car will kinda shake when I grabs the gear doesnt matter what gear if your slowing down and downshifting it does that. Also when at a dead stop putting it into 1st is kinda hard but after go thru the gears its smooth it happens to 3rd gear to but not all the time.
Not sure if you guys could answer some of these concerns.
Thanks again
Old 02-05-2019, 10:28 AM
Get the right motor resistor,. One for your climate system, which is either manual or auto heat temp setting.
How is the clutch?
Bad motor mounts can cause shaking.
Old 02-05-2019, 08:53 PM
How is the clutch?
well the clutch seems to be okay I'm not sure if it the original one. I also wouldnt be surprised if it is. But I would like to replace it and the flywheel. I'm sure it would help with shifting gears.
Old 02-06-2019, 10:39 AM
Try starting out in 2nd and determine if the clutch chatters.
sarvnaz123
12-22-2015 04:59 PM
h.cardle4
10-21-2013 10:56 PM
h.cardle4
10-19-2013 08:51 PM
danielrogers
09-21-2009 10:43 PM
noel_99camry
07-18-2009 03:46 PM
Quick Reply: 01 camry 5sp
