1995 Camry 5s-fe
RE: 1995 Camry 5s-fe
The 5S-FE is not a performance engine due to its head design. There are after market camshafts, turbo (works well), headers, but otherwise not a whole lot.
The engine was designed for MPG and daily commuter driving.
Should I put a new transmission in it? Currently it has an automatic? My friend says that if I were to put a turbo on it now then I could only run 4 or 5 psi, but if I switched out the transmission then I could run more.
Not the turbo expert here.
5psi is good enough if you want to keep the engine from breaking rings, etc. The trans should be OK, install a second trans fluid cooler. This should give you over 150 HP at the tires.
About 8-9 PSI seems to be the max boost and still have OK engine life.
If you do go the turbo route make sure you read up on it first. Try www.toyotanation.com for posts on actual experience. One suggestion that always comes up is to install some kind of overboost protection in addition to the waste gate. Overboost does happen and can blow the engine if not managed.
LegionOfCamry
04-04-2013 04:29 AM
ggcc
04-27-2007 05:15 PM
oleg_8831
06-21-2006 03:05 PM
