2009 Camry se with code p2714
Old 05-27-2019, 07:58 PM
Bobby190's Avatar
Default 2009 Camry se with code p2714
Hey guys
Need a bit of help or opinion ok I have a 09 Camry with 139,000 so the other day the check engine light came on so I had it checked and it gave me code p2714 which is pressure control solenoid D performance or stuck off . So like 2 days later the check engine went off
Old 05-28-2019, 01:30 PM
The issue is the solenoid, solenoid plunger or solenoid wiring.
This solenoid is also called "SL." Controls torque converter lockup.
Need to drop the trans pan to access the solenoid.
jackwagon
05-26-2017 09:11 PM
None77
09-23-2014 09:25 AM
geno02
01-01-2012 10:52 AM
Eliezer3
06-08-2010 07:06 PM
Quick Reply: 2009 Camry se with code p2714
