2002 Camry Stalling
My 2002 Camry LE 4 cyl, keeps stalling on me. It acts like it's running out of gas, yet the tank is full, then it stalls. I have to wait a few minutes before it will start back up again. I justhad it in the shop 2 days ago, and had the recommended 60k tune up and theyflushed my valves. I asked about having the fuel filter and/or pump looked at and was told it shouldn't be the issue. Car still stalls. Any suggestions?
RE: 2002 Camry Stalling
get your crank positioning sensor checked out.
I agree. Get the crank sesnor looked at. See if you notice anY dummy lights " check engine light" ect. That will give you a better idea of the problem area. A new set of plugs can never hurt. Specially if chemicals have been run threw them
No dummy lights go on, and it only seems to stall when its cold. After waiting a few minutes it will restart with no problems and run just fine. I will look into the crank sensor.
Also, can you tell me where the crank positioning sensor is located and how hard would it be for me to check it myself?
Also, is it an expensive part to replace.
Check your crank again my friend.. But I'm thinking that your alternator might have a problem over there...
_______________________________ Mercedes S280 Alternator l Buick LeSabre Seat Belt |
definately get your fuel filter replaced. ive had that probem before. besides it should only be a 5 to 15 dollar part and it should be pretty easy to instal
my wife camery did the same. it stalled when she stop at a stop sign or light. i replace the temp sensor and it worked fine. do a search on yahoo. on stalled camery and there should be a bunch of info there.
The Check engine light finally came on and the computer said it was my charcoal canister and my CVC valve that needs replacing. They want to charge me $1150. because they have to pull the whole tank out to get to it! Ouch!!! Any suggestion on doing it cheaper?
