2003 camry v4(2azfe) to v6(1mzfe)
I am most likely gonna need to replace my engine and was noticing that a v6 1mzfe is a good bit cheaper and would also make me happier...I think the computer/wiring harness would need changed??? What else would be problems or possible areas that need changed/updated?
The 1mzfe was offered as an option for Camry, not sure when it was replaced be the newer model V6.
You will also need a different trans beside computer and wiring.
The parts should drop into the car but suggest you find another 4 cylinder rather then try this engine/trans swap. A lot of work, money and it will lower the resale value of the car.
Andre Diaz
02-23-2015 07:08 PM
Huo Yuanjia
10-21-2012 01:58 AM
