2008 camry LE valve cover install
I have a 2008 camry le 2.4 L and ready to reinstall valve cover. All has been cleaned and prepped. My question is I've read people say to lay down a bead of peratex either high temp red or the right stuff around entire perimeter of the engine head and then install the valve cover with the OEM black rubber gasket installed. Is it necessary to do that entire perimeter with the rtv? Or only on those two areas by the timing chain area.?
mjcloud19
Apr 30, 2017 08:47 PM
