2009 Camry se with code p2714
Hey guys
Need a bit of help or opinion ok I have a 09 Camry with 139,000 so the other day the check engine light came on so I had it checked and it gave me code p2714 which is pressure control solenoid D performance or stuck off . So like 2 days later the check engine went off |
The issue is the solenoid, solenoid plunger or solenoid wiring.
This solenoid is also called "SL." Controls torque converter lockup. Need to drop the trans pan to access the solenoid. |
