3rd gen to 4th gen swap?
I have a 99 Camry LE with a rod about to go out. Rest of car is great. I found a 1996 5sfe cheap with 121k on it for $200 but I'm not sure the heads are the same and if the 99's other stuff will bolt on and work (cam sensor and coil pac ignition in particular). If not just let me know and I'll pass up the deal. Thank you.
I just wanted to know if the good longblock I can get can use all of the externals from the 99 and be made to work.:)
