5 speed
Hey I have a 1mz 98 Camry with an auto trans and I want to swap it to a 5 speed. What trans would be the best trans to get and what all would j have to change out to do it as far as ecu and electrical?
you need a donor car or a half cut has to be a 1 mz 1998 manual gearbox set up
it will have all the things you need to complete the task without making lots of trips or trying to source bits and pieces sell the unwanted scraps a quick list of needs flywheel /clutch /pressure plate gearbox master and slave cylinders / CV joints/ manual gearbox mount ? shift stick/stick cables/ pedal box instrument panel/ center console radiator if you have cruze the cruz pedal switch using the manual engine ecu saves guess work possibly a manual starter motor ? |
