93 camry xle 3.0 v6
I have had to let the vehicle idle until warm upon start to get any acceleration. If I don't and try to get in start and go the gas pedal just revs the engine producing no acceleration.
What could be the problem for this? Spark plugs? Transmission? |
Have you tried all gears, 1st, 2nd, R, etc?
Is the trans fluid full? Do you feel the trans shift into gear when moving the selector? Indications such as a slight bump or sound, RPM drops slightly. A trans shop can do an hydraulic pressure test. The trans has a pump that generates trans fluid pressure to allow the trans to shift. Could be the fluid pressure is too low when cold. |
All gears? It is an automatic. Drive and Reverse equally.
Last I checked all fluids were appropriate. I do feel a shift when putting into gear. I will look into a transmission pressure test. |
The trans can be manually shifted into 1st, 2nd, etc.
If you can feel the trans shift when putting into gear and no forward motion in D or R then have the trans looked out. |
