94 Camry 4cyl swap to older engine...
I picked up a 94 camry with a hole in the block for ~$200 and an 83k engine & trans out of a 92 for another $400. I got the old engine & trans out and am wondering if everything will just plug right up? I think the 94 is OBD II, but the 92 might only be OBD I. Is there any difference between the two before i get everything swapped in?
Chad |
RE: 94 Camry 4cyl swap to older engine...
your mit need to swap the sensors.
