95 Camry Extreme Vibrating when turning from idle
My 95 Camry seems to vigorouslyshake and vibrate in the front of the car, and I feel the shaking through the steering wheel. This only happens when I'm stopped and accelerating by turning left or right, sometimes straight.
Replaced the shocks recently, but I'm not sure what the problem could be. Any help would be greatly appreciated. |
RE: 95 Camry Extreme Vibrating when turning from idle
It sounds like your power steering. you shoudl check the power steering fluid, check if its low or not. I use to have a similar problem which resulted in fixing the power steering.
also check your motor mounts!!!!![:@]
Engine and car shakes when the car is standing still?
