97 camry eng replacement
wife threw a rod on the 97 camry 2.2 4cyl, only 150k on it. what engine beside orig can I basically bolt in from other type toyota and what year camry's use same engines. car is great overall so want to keep it since bought it new. thanks.
RE: 97 camry eng replacement
Well, there aren't really any other BOLT ON engines aside for the original 5S-FE. Another option you have is the 1MZ-FE V6 but that too will need some custom parts to be put on.
its you're wifes car right? just replace it with the same, it'll sure give her fewer problems.
