97 camry engine is surging
Old 10-15-2012, 06:59 PM
Lindsey Spence's Avatar
Unhappy 97 camry engine is surging
my 97 camry is surging under acceleration? while going through lights in a straight line, while still have half tank of fuel, suspect fuel pump but would like a second opinion!
Old 10-15-2012, 09:31 PM
V6 or 4 cylinder?
Surging at idle, etc also.
Old 06-18-2016, 06:30 AM
gregs396's Avatar
V6 or 4 cylinder?
It's a 4cyl. It just stalls at idle, and will surge at a higher RPM. No CEL at anytime, and the light is functional. I also pulled the EGR valve off.
Old 06-18-2016, 06:58 AM
gregs396's Avatar
V6 or 4 cylinder?
Old 06-19-2016, 09:42 AM
Hot/Cold/Both?
Have you checked for vacuum leaks?
A plugged converter can cause this.
Old 06-20-2016, 06:56 AM
gregs396's Avatar
Hot/Cold/Both?
Its only after warming up. There's no consistent pattern though. Yesterday morning I figured that I would replace the plugs. They old ones were the wrong type with the single tab. After changing the plugs, I drove the car and ran it at idle for 35 minutes without an issue. After a drive, I was pulling back into the neighborhood and it stalled and began surging again. I have a former Toyota dealer mechanic in the area, and had him drive the car. He was leaning towards a bad coil pack or a bad injector. He had 2 good coil packs that he gave me to swap out. After that, it stalled once right away, and started to buck as soon as I went for a drive. I came back home and ran the car at idle, both in and out of gear, and ran perfectly. I even ran the engine a various RPM's from 3500 to 1000 for a half hour, and it never missed a beat. Going to drive it again this morning, stay tuned...
imabadczech
10-13-2011 06:23 PM
corey l
04-30-2010 09:47 AM
ckelner
04-20-2009 07:09 PM
Mikesta
03-20-2009 08:00 AM
mychem23
02-20-2007 06:33 PM
Quick Reply: 97 camry engine is surging
