Auto. to Manual Conversion
Hey all! Great site. I have a 87 Toyota Camry that I am currently converting to manual. I think I might have run into my biggest problem so far.(after cutting holes in the firewall for the clutch cyclinder and cables) I was wondering if anyone knew If the bolt pattern in the flywheel of the auto is the same as the bolt pattern in the manual. I dont want to have to switch the entire engine and transmission, Id like to just slap in the manual, and away we go. If anyone knows the answer, it would be greatly apprieciated. Save me a lot of time, rather than pulling the Auto. out before I know if the flywheel patterns are the same. Thanks!
RE: Auto. to Manual Conversion
they should be the same...but not 100% sure..more like 90%....call the toyota parts department and have them do a parts number check on the crank for that year a modle..see if the manual is the same crank as the auto..
