broken thermostat housing stud
I have a 2001 6 cyl Camry and I broke one of the three studs that hold the housing. How do you get it out?
all three is bad luck
broken because of corrosion if the engine block side of that housing for the thermostat cover can not be removed or purchased two options if a bit of the stud is workable heat up or weld a nut to what is viable then undo or loc-tight two nuts to remaining thread to undo carefully if broken at the base of the stud drill them out straight ... tap a new thread and helicoil kit three new studs |
