Camry 2005 TRD Clutch
Old 10-10-2008, 05:23 PM
Camry05WS's Avatar
Default Camry 2005 TRD Clutch
Well the first owner of my car had a TRD clutch installed when the car had less than 100 miles. Now the car has 65k on it and it slips a little bit in first sometimes and does not shift well into fifth. My dealership said that it was the pressure plate. While they fix the install a new plate am going to have the clutch replaced. Should I get a new TRD clutch or are there better brands? I think that I can use a Scion Tc clutch because the engine is the same right? The part numbers are the same. Well let you know what I should do I would like to get the best clutch that I can because I plan on keeping the car until I am done with grad school.
Thanks
Old 10-26-2008, 09:34 PM
Viktor's Avatar
Default RE: Camry 2005 TRD Clutch
Yea the scion tC has the same drivetrain. It should work no problem.
J2Performance
12-13-2007 11:55 AM
J2Performance
12-13-2007 11:46 AM
J2Performance
12-13-2007 11:25 AM
J2Performance
12-12-2007 06:20 PM
J2Performance
12-12-2007 06:05 PM
Quick Reply: Camry 2005 TRD Clutch
